Kosei K-1 Wheels with BFG Drag Radials Arrived
Just got my 2 15" Kosei K-1 wheels (13.5 lbs each) clad in BFG Drag radials 205/50/15.
Got the idea from the SRT forums where lots of folks are running them with great results.
They fit calipers fine and drop the front end 1 to 1 1/2". Plan on pushing them hard at the strip this weekend. In the meantime made a trial run and they really do grab! Looks like I should be able to leave with NOS on in 1st Gear. I also assume that due to the size difference my final drive ration will go up giving me more pull down low.
I hope the automatic will not shift to od before end of 1/4, but even if so the hook up and mid range should really help.
Lack of traction has been my biggest et problem. I will let you know the difference.
