put the auto meter 2 gauge pod with gray faced boost/vac gauge and trans temp. I had to pull the pan to weld the adaptor in the trans pan for the sensor. the car had 500 miles on it. I was surprised to find the magnet in the pan had collected a lot of stuff and there was some metal in the pan also. I think this maybe normal most people don,t pull the pan after 500 miles. Get 14 psi boost and if you want gas mileage the vaccum gauge really helps. the vinyl dye works great on the pod. tried to use double sided tape to hold it on but ended up having to drill and use the push pins that came with the kit hated to drill a hole in the original part. will have to order one to have when I sell the car and keep the gauges
