OK, I got mine working!! It __IS__ the black wire with the stripe, and it ___IS__ the wire marked above in the picture as 12V constant. You do NOT use the wire marked above as ACCESSORY. The one part of my install that was incorrect was. YOU NEED THE PURPLE WIRE, and you NEED to run it to the either 1) the parking break or 2) A ground.
The best way is to use the same location as pictured above with the screws in the fuse box. ALSO, one thing that I haven't seen anywhere is you NEED the brain to be set to "B" on the switch that is either A or B.
-Good luck, peace and chicken grease!
Black 03 GT - silencers removed. PT Cruiser 3BL. Much more to come
