Old 30 Aug 2011, 01:22 pm
PT_Patriot PT_Patriot is offline
Default Re: 04 PT replaced battery and now when starting runs for 5 sec and RPMs go zero it s
Also check the IAT sensor on the flexible tube between the airbox and throttle body. I commonly forget to reconnect it when changing the battery or air filter since I usually completely remove the tube and airbox.
Since you just replaced the battery the problem could simply be the PCM needs to relearn how to control the engine. After 95,000 miles the engine is probably not going to perform as well with the default parameters that the PCM has after disconnecting the battery. Give it some time. If it doesn't get better by the weekend it is probably something else.
PT Patriot
2002 Patriot Blue PT Cruiser Touring Edition
