Thread: Boost pressure
Old 22 Oct 2011, 02:24 pm
2004GTMAN 2004GTMAN is offline
Default Re: Boost pressure
Originally Posted by starman View Post
The only way I know is to buy a stage 4 kit for a Dodge Neon. You get a new turbo, 4 new injectors, high pressure injector pump, new ECU. 280 hp on 93 octane, 300 hp on 100 octane. Downside: it costs nearly $4000. If you want more acceleration, cheap way is to put 14" wheels on front. BTW, if you are willing to give up a little hp, the turbo engine runs fine on 89 octane.
This is a joke, right? Everything is wrong with this answer. There is no stage 4 and the GT does not run "fine" on 89 octane. Can't believe cheap people who will save a couple of dollars a fill up using a lower octane than specified that might cause engine damage.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
