The most confusing aspect I found was the information NOT in the directions, like how to disconnect the various connections. Again, if you take your time, don't force anything, you can figure them out.
There are a couple of inaccuracies in the directions--there are 4 bolts in the PCM bracket, not 3; there is only 1 hose attached to the thermostat housing, not 2. Again, take your time, look, re-look, and it will go fine. Depressurize the fuel system, have a couple of rags
available to catch the remaining fuel when you disconnect the fuel line from the fuel rail. However, if you've done the BOV, you've done the hard part already.[8D]
You're gonna love it.[?]
Light almond GT w/5 spd, aluminum gas cover, 400-watt amp w/Kenwood 3-ways in rear, EJECT power button, custom dual exhaust, hidden trailer hitch, mini-flames by Streamline, mini-flames around windshield washer, \"amx\" turbo-up custom intake, Stage 1, BTG strut tower brace, Eibach Pro-Kit Springs, Custom 17x7 wheels.
