StephenR, your assumption about the switches is absolutley correct. they are ON=LED and OFF=NO LED. There are no other switch terminals available on the rocker switch pod to use. If you want to use the switch pod for breaking a circuit it will be necessary to use a relay for each circuit that you want to disable. If you'd like I can make you a schematic that shows how to do this. Almost all leds built in to switches are that way. I think the relays are a couple of bucks each. If I can be of more assistance here, e-mail me & let me know.
Alan
