Do the pcm first I did not take the intake clear out of the car took the back two bolts out and then the front a used a bungie cord to hold it up out of the way while I did the injectors.Also only let enough antifreeze out to get the level below the thermostat use a small hose on the drain valve to keep from having a mess it wants to drip the full lenth of the tray under the radiator if you don't. you only need to drain about 1 Qt. If you have a auto trans the warm up time and learn time will take you longer than the pcm and injector change Good luck PS you will love it. Just got my BOV today and took the car out with the g tech pro got a best run of 14.92 at 98 MPH with the tires spinning through 1st gear. with good tires and power braking I think the car would run low 14's
Don
