you can correct it. the two z shaped brackets that you install on the bottom of the bumper for support are you key elements here. You need to lift up on the bumper and find a spot where the bumper is aligned perfectly....then you mark the spots on the bumper and attach the brackets to those points. There is no gap on mine. I'm the expert on the crusher
I can be more detailed if you really need it too.
