Old 10 Nov 2011, 06:21 pm
CREWZIN CREWZIN is offline
Default Re: Timing belt went out, how can I check the valves?
Maybe others will jump in, but as far as I know, you need to replace the timing belt (do the water pump and upgrade your tensioner while your at it) and then you can check on the valves. The engine needs to be turning to do a compression check. Unless you were at high revs when the belt broke, it's a good chance yo didn't do any internal damage. It's a non-interference engine which means the valve can't hit the pistons when the belt breaks but opposing valves can hit each other when the engine goes free wheeling. Of all the owners on this forum who have gone too far and broke the belt only 1 or 2 have had internal damage.
OK, Turbo Ducky has come up with a different way and agree with Ducky on being short on the hours for replacing the belt.
