Old 10 Nov 2011, 07:31 pm
TurboDucky's Avatar
TurboDucky TurboDucky is offline
Default Re: Timing belt went out, how can I check the valves?
As long as the crank is not on top dead center, you'll (he'll) be fine. 1/4 to 1/2 turn off should be good. The design of the 2.4 is that when pistons 1 and 4 are up top, 2 and 3 are on the bottom. Anything other than top dead will have all 4 away from the top.
And, you can rotate them independently.
-Gary-
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
