Old 10 Nov 2011, 07:50 pm
UptownSport's Avatar
UptownSport UptownSport is offline
Default Re: Timing belt went out, how can I check the valves?
You could pull both cams and do compression test, by that time you could almost
do the head, though!
Never done this, assume (with good valves) it'd be in the very high category!!!!!
