Here's my version of a "real" cold air intake:
A K&N cone filter is located below the driver's side wiper cowl cover. The rest of the intake consists of a 3" od aluminum tube connected to the filter, a 3" id upper flex tube, a 3" od aluminum intermediate tube with connections for stock breather hoses, and 2.75" rubbber lower elbow for connection to the turbo. The cowl cover has holes drilled in it to allow the entry of fresh, cold air from the hi-pressure area at the base of the windshield The weatherstripping is intact sealing off the engine compartment. The filter is shielded from rain under the portion of the cowl cover that is solid. Water that enters the filter area is drained away by factory holes.
This is NOT a solution for noise-sensitive drivers. At WOT throttle it sounds like a jet aircraft on a take-off roll!!! But that's OK with me!
2003 Electric Blue PT Cruiser GT 5-spd
MOPAR Stage 1 kit
Custom Stage 1 emblem on rear hatch
Greddy Turbo Timer
AGP factory surge valve blockoff plate
AGP/TurboXS Type H-RFL BOV
160 degree thermostat
Magnacore plug wires
Champion RE14PLP5 Double Platinum plugs gapped .050\"
Screamin Demon coil
Momo shift knob
3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges
Stewart Warner Shift Light
Streamline Designs third brake light overlay \"Turbo Cruzer\"
Rear splash guards
Rear spoiler
Hidden Hitch
Ichiban pedals
Streetglow Xenon headlight and foglight bulbs
PCV line oil seperator
Firestone Firehawk SZ50 215/50R17 tires
PT Tuning axle back exhaust and muffler
Mr. Dyno vehicle performance computer
Pioneer DEH-P77DH AM/FM/CD
Kenwood KSC-WA62RC The WooX 30w x 2 powered subwoofer
