Originally Posted by UptownSport
You could pull both cams and do compression test, by that time you could almost
do the head, though!
Never done this, assume (with good valves) it'd be in the very high category!!!!!
My mech used a compression test (by manually rotating the cams so each cylinder had its valves seated) - then adding compressed air and watching a gauge. A leakdown test. Once he determined that 2 cylinders had no compression he pulled the valve covers to verify.
