Old 10 Sep 2003, 05:12 pm
Ian-PT-GT Ian-PT-GT is offline
I am sure you won't have any problems installing it with that practice.
The only thing is the four screws holding the PCM to the frame, the instructions say 3 (Typo).
Also, make sure you remove the original gasket completly. Mine was stuck against both halves and took me for ever to remove all those parts without falling inside the lower manifold half. I placed clean rags inside each hole and scraped the crapy gasket from the holes out. Little by little and slowly....
Other than that is very simple.
read the instructions a few times before the actual operation to make sure you understand the steps.
Ian
