It is really not that hard exept that you may have to clear error codes after you are done! All you do is pull the fuel pump relay from the Power Distribution Center. The cover of the PDC tells you were it is located. Start and run the engine till it stalls. Try and restart engine till it wont start anymore. Turn ignition key to off. Return relay to PDC and you are done.
