Installed the S1 tonight. Only had one problem.
The front thermostat bolt had a threaded shaft with a nut that had a metal pressure plate over it and then another nut. That was a pain to get off. Second i sheared the other thermostat housing bolt (frickin torque wrench was at only 100 in/lbs (should torque to 110). Got the bolt out but have to get a replacement before I can refill the coolant and pressurize the fuel system. Otherwise it was fun until I sheared the bolt. Then I felt like puking. You always know a fraction of a second after that you over turned the bolt
[xx(]
Oh and on mine, there were (4) bolts holding the PCM bracket, not 3.
Homepage:
