  #11 (permalink)
Old 14 Sep 2003, 10:17 am
macster macster is offline
Send a message via AIM to macster
PT
You might want to take a good look at the idler puller and pwrstring/A/C belt area. I would jack the car up pull the right inner W/Well sheild and bottom splash shields out. It should take you about 10 minutes, unless your car is lowered like mine, then it takes 12. Anyway, what this does is as follows, its provides much better viewing in/around those areas, plus you can really look if you have an inspection mirror and a MAG light. You really don't want anything like that floating around in that area.
FWIWM2C
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
