Thread: Boost
  #12 (permalink)
Old 14 Sep 2003, 02:01 pm
PTGT Redman PTGT Redman is offline
got my S1 installed, checked all the lines and stuff. At 2nd gear WOT i pull maybe 13 pounds of boost. For some odd reason I can't tell if it is running stronger thru the gears.
the exhaust has a nice tone with some burbles and pops. But 1st gear I do't drop, so i haven't tried anything with that. What should I expect from the 5 spd?
Only changes are a 2.5" exhaust from the cat back and aftermarket 17x8" wheels.
No leaks in coolant system and the car otherwise runs fine.
The boost gauge is electric. it has it's own MAP sensor between the gauge and the tap in the vaccuum line. Pre-S1 boost levels were 10-11.
Homepage:
