  #12 (permalink)
Old 15 Sep 2003, 02:18 am
TX02PT TX02PT is offline
In ref. to the no turn signal being illegal, in Texas (other states may be different) the law is as follows : (Transportation Code) TRC 547.324 Turn Signal Lamp Required : Turn Signal Lamps: shall be mounted at the same level and spaced as widely aspart as practicable on the front and on the rear of the vehicle; and may be included as a part of another lamp on the vehicle. A turn signal lamp shall emit: a white or amber light, or a color between white and amber, if the lamp is mounted to the front of the vehicle; or a red or amber light, or a color between red and amber, if the lamp is mounted on the rear of the vehicle. Must be visible in normal sunlight at a distance of: at least 500 feet from the front and rear of the vehicle...Basically I interpret this to mean that it is okay for the blue car above if the lights on the front bumper are hooked up to the blinkers. Hopefully this helps, also contact your local department to see if you can see a copy of the motor vehicle handbook and penal code. Sorry for the long post.
