quote:How did you get the stock ball off?...
Using a 3mm allen wrench find the set-screw on the front of your ball knob (about 1/4 inch up from the base) and remove it completely. Then pull up on the ball and it should "pop off" the shaft. It may be a bit tight--mine was not. You shouldn't have a problem. Good luck.
