Still not clear what failed here - sounds like a seal. If a seal goes away, it usually isn't because of the type of oil used. A worn thrust bearing will cause a turbo to smoke a little (if you run too much boost too often), but not normally a huge cloud. Is the car back from service yet? This sounds like maybe a valve stem seal, especially right after startup.
PT GT - Fastest damn lease car I could hope to have...
