Old 15 Sep 2003, 09:16 pm
ElectricBlueGT ElectricBlueGT is offline
Punch,
I have the GT shifter knob that Gary and Alan (GearHead) have. The shifter ball is internally spring loaded. You press down on the ball in order to move past the shift detents. As soon as you get the gear you need, stop pressing on the ball. In AutoStick mode, you tap left or right, just like you used to.
Gary and Alan,
Does your shifter knob have a little play? Meaning, can you slightly turn the ball an 1/8th or so of an inch? The base doesn't move since it is located by the allen-head pin. I just notice a "jiggle" if you inadvertantly grab the ball and try to twist it. No danger foreseen. I just want to know if it is normal.
Thanks,
Scott
\"If you choose not to decide, you still have made a choice.\"
