Hyracer, the alternate gears are from a non-turbo car. I was shifting into overdrive with automatic. This was a result of the BFG drags being almost 2" shorter than the RSA's. That was the only size I could get that day....To remedy the problem, I had to effectively change the final drive ratio...(like have 4.56 gears in the rear end.) This will net you a higher MPH and LESS torque available at the drive tires.
Ptturbine
PTTURBINE
Toronto
13.48@105.36
