In case you might be interested, I've ben using a program called Earthstation 5 for awhile now. It's a P2P file sharing program that runs free streaming movies that play in windows media player 9.
it's a little difficult to use at first but if you sign into the forums theres a great bunch of people that will help you with anything you need.
ES5 is nice because unlike other p2p networks, these guys are running servers based in a refugee camp in Jordan
basicly the RIAA wont go anywhere near them. the program also allows you to log in to stealth mode that blocks your IP address by connecting through proxy servers, as well as letting you block specific IP addresses.
theres a ton of other features but anyway, check it out
http://www.earthstation5.com/
they're in the middle of adding more movies so the streaming movies may be down at the moment but i'm not sure.
for an example try opening windows media player, go to file, open URl..paste this address mms://213.152.100.152:14524/es5/movies/Bad%20Boys%20-%20256.wmv
that should open Bad Boys, it all depends on your system setup. some movies require different codecs (coders/decoders)
note: dont even attempt this unless you have a broadband connection
