quote:Originally posted by Ptturbine
I think you are way of the original thread as well. But it still is an interesting topic(a bit). If the pcm works when we plug it in so be it if it doesn't we have reason to worry. Until we can see how they work via a laptop, who really cares? What will this do for YOU? I think nothing.....At any rate....Of course the dealer CAN'T flash a 2004 or a 2003 controller with the STAGE I!!!!! We don't have the software! Who on earth came up with that idea?
Taken in context, that comment was in response to possibilities between 2003 Stage I equipped and 2004 GTs. It came from the fact that they both would have the same injectors and PCM. All that differed would be the programming. At that point I brought up the thought that a 2004 owner could possible be an hour's labor from Stage I; based on the cost/time for applying a Flash Upgrade.
It was not a discussion about software availability at that time, and I think that 3barboost and I have pretty much covered the concept of property rights, and that the dealerships would not have access to the Stage I software. At the point the comment was originally made, that point hadn't been mentioned; or clarified.
Understanding a bit about the way they work before plugging in a laptop just may help in knowing what to do when you plug in the laptop. It's all relative.
In my case, using a data logger will help a great bit in understanding the programming flow. But, then again, I am concerned with learning about the PCM and how it maintains control. I will probably not be adding a lot of aftermarket gear until I get an assurance that it won't degrade performance and longevity. I like the compatibility between the staged upgrades and the stock system, and my end goal is not to try to redesign the entire system.
You see, that is the wonderful thing about diversity; different people have different concerns and pursuits. I guess that is where the "different strokes for different folks" concept came from.
As far as trying to belittle a comment by taking it out of context, then using info that was gathered far after the comment was made to justify your position - Well, we will just have to let the forum readers judge that on it's merits; or lack thereof......
