Old 04 Apr 2012, 05:25 pm
CREWZIN CREWZIN is offline
Default Re: I'm back lol...well the gremlins are!
The EVAP leak codes usually tunsr out to be either 1) you got gas in the last day or so and didn't click the gas cap 3 times to make sure it's on tight or 2) the gas cap itself is not sealing properly.
Not a big thing to worry about. First check to see if the cap is tight, then wait a day or so to see if the code goes away by itself. The computer will check a number of times and if the cap is sealed and no further leak detected, the code will go away.
Of course with all the jumble of codes that you have it will be hard to know when just the leak codes go away.
