Thread: Cold Start
Old 29 May 2012, 12:27 pm
CREWZIN CREWZIN is offline
Default Re: Cold Start
Milkman,
I seriously doubt that it's the hot water getting to your turbo that makes it run better/smoother after a cold start. I would check your IAC and IAT for possible malfunction. Even you 02 sensors could be causing a problem.
You give us no information about what you may have done to solve this problem or how your 03 turbo has been taken care of. When was the last time the plugs and wires were changed? What are you using for plugs and what gap are you using? What's the mileage of the engine and is your PT have the Turbo Lite or the full GT? If a GT are you using premium fuel?
Also, please don't post your question in more that one area of the forum. Makes it confusing for the people that are trying to help you.
