Thread: LED Plate Frame
Old 28 Sep 2003, 09:02 pm
Dalite Dalite is offline
On those Tag Frames, there is a wire going to the parking lamps, one to the Brake lamps and one ground. Let's say Red goes to park lights to turn it on. White goes to Brake lights to turn them all on and make a brake light.
You can use a double pole - double throw (DPDT) Center-off mini toggle switch mounted in the compartment that your jack stores in. Center Off - 49 state legal. Up - brake light lights up all leds as another brake light (probably at least 25 state legal). Down, when parking lights are turned on, the message scrolls and the brake light still over-rides them (good for showing the car, and when you just feel lucky... This location also give you access to the harness that feeds both park lights abd brake lights.
If they wire similar to the Neon Streetlights - Neon Fader Frams, I can send a schematic on how to wire them up. I probably still have some new DPDT Center Off Mini switches around here too.
