Old 06 Feb 2004, 10:02 pm
Ant Ant is offline
Default Dyno Results for Hahn Turbo PT!!
After driving the car for 1 year with the turbo setup I finally made it to the dyno today.
Little history:
Within the past few weeks I put in a Wideband O2 sensor for constant monitoring during boost, GT intake, bored TB, and 30 lb injectors.
With static FP set to ~25 it idled a little rough but that is the # that seemed to work best.
My goal for going to the dyno was to:
1. get the AFR curve in a good/safe range
2. see if we can dial out some of the overlap and get it to idle better.
Both were accomplished!
OK now the results:
17 PULLS!! yes that is correct 17!
9-10psi
2nd pull had me very safe on the AFR (very rich)
184.39 HP 152.85 TQ
Once we got the AFR on (~12:1) we were closer to 200 HP
Next was adjusting the cam gears. Nick Riley from NRGY HEADS did those adjustment, he has done this MANY times so I was able to learn from him. I was in charge of the Fuel.
Run 11
229.29 HP 258.40 TQ
We tryed turning the boost up to ~11-12 and experience some break up. Ended up pulling close to 240 HP but it was unsafe at those levels so turned it back down.
Car idles nicely now with the 30lber's. I think they are capable of handling close to 300 HP.
I have the Crane ignition w/timing retard which needs to be installed next. Then I can get that boost up to 12-14 and put some real #'s down.
The #'s I posted were peak. The goal is to make more power accross the board and not shoot for seeing the highest #'s.
I would say for the relatively low boost levels I was running, the power is very respectable. There is certainly a LOT more in this minivan!
BTW the little method I used for adjusting FP,( I shared with Bob and OC Cruzer, AL) at higher boost levels worked flawlessy. When I learn how to post the charts you will see that AFR went almost immediately to 12:1 and stayed very steady throughout the run. This was from ~40mph-112mph at ~55psi WOT.
