Old 30 Sep 2003, 11:23 pm
gooberff gooberff is offline
The koni struts are inserts. in order to use them you must disassemble the spring fron the strut assembly. after that you drill a hole in the bottom to first drain the oil then enlarge the hole so the supplied bolt will fit. then you cut the top off the stock strut so you can remove the internals. the koni strut is inserted inside the modified stock strut body and then secured with the bolt through the bottom. there are some other small steps but that's the main parts of the work.
i beleive the gt struts are different than the n/a pt struts so thats why i am wondering if they will fit. basically, is the internal diameter the same on both stock stuts?
