Old 15 Feb 2004, 03:53 pm
ptgtcb ptgtcb is offline
Default Stage I boost levels?
Those with stage I only, What amount of boost are you making. I finally installed my boost gauge and I am only seeing about 8psi in fist, a steady 11 psi second through 5th, if I shift very quick I can get about 13psi steady to about 5,000 RPM then it starts to drop off going to 9psi at redline. This sounds kind of low to me. It is about 64/65 degrees outside. I tapped into the brake booster line,which should be a good source? Don't use a plastic tee! []
I know this info is posted somewhere and I did search, but it must be buried in with other topics? LMK
Thanks,ptgtcb
(The only other mod is the amx turbo up pipe to stock box)
