quote:Originally posted by Culprat
When I did the install it carried 15.25 pound of boost
to 6000 then droped to 10.5 pounds at the shift,at shift
completion it went back to 15.25 until you let off the loud
pedal.
Torque is down also three turn of the tires at launch.
Yes it is slower!I know it's 45 I live in battle creek, something is not right.
Ralph from Mopar didn't return my call ether.
Can you describe anything else with regard to your problem? Any fault codes? Did you get a bad tank of gas? I'm baffled why it would suddenly drop off unless you have developed some sort of boost leak, like the SRTforums types keep plumbing their MBC to the BOV line and making it leak - lowering boost.
I can't diagnose with no info.
