Old 24 Oct 2012, 10:30 am
NitroPT NitroPT is offline
Default Re: How should I be charged to change plugs and wires?
WOW!
First the OP clearly does not want to do this work! So telling him how easy it is for some of you to do does not help him at all!?
Also "speed tuning" is a direct action for messing something up! I would fire you if you worked for me and rushed any job! I pre inspected all parts before they are installed and that does not count as labor time. Some just rush in and install whatever part and then later cry about problems.
I do think that the mechanics is a bit inexperienced if he is judging the work solely from the Labor rate and not experience which is usually less then prescribed.
What is his labor hour rate? If it is in line with the labor rate then he not "ripping" you off it is just his rate! Most licensed shops in California get 100 -125 per hour labor rate. It is that way in most other states as well. Dealers get even more.
I do think it is funny that the quote is 203. whats with the 3 bucks?
