hmm came across another choice...
Q-Logic - 2 x 10" and this one actually sits in the bottom set of notches - made of ABS though so while it'd most likely be a perfect match for trim panel color I have no clue how a plastic enclosure would be sound-wise...
http://www.sounddomain.com/shop/item...093&vq_id=none
Anyone out there ever heard subs in a ABS enclosure?
Specs:
Model # QL-C1PTC210A01
Description: TYPE 1 DOUBLE 10" SUB ENCLOSURE, BLACK
Extended Description: Custom-fit sub enclosure fits on floor or storage rack of rear cargo area.
Features:
ABS plastic cover and grills match your interior trim
Spring-loaded terminal cup with 5-way binding posts
100% 5/8 in MDF enclosure construction
Dado groove and miter joint design for ultimate strength
Separate sealed chamber for each subwoofer
0.65 cu. ft. internal volume per sub/ 1.3 cu. ft. total vol.
Includes woofer mounting screws, poly fill, speaker wire
There's a retailer pretty close to me, will see if they have one in stock I can give a listen too...
