If you pull the driver's side "A" Pillar trim (the plastic piece that runs from the dash to the headliner at the driver's side of the windshield), you should see a wire harnes behind it that runs from under the dash to the headliner. This harness should have some of the following color wires: green, pink, orange, orange, white, black, blue, brown. red, white.
If they are present, there is a good chance the harness is there for the overhead console. From there , you would have to drop the headliner down enough to verify the connector and harness runs to the center of the roof, near the windshield - where there should be an obviuos area that the overhead snaps into.
You would have to get an overhead console (hopefully from a junk yard), and get some measurements on where to cut the headliner to install the overhead console. The cut-out would have to be fairly precise, as the console uses the headliner as half of it's mounting.
Unless you are ready to undertake a custom installation that will require a lot of prep, research and careful measuring, this may be a project to pass by.
