Thread: Hood Lift Kit
  #19 (permalink)
Old 14 Oct 2003, 09:03 pm
Nova69 Nova69 is offline
Install is very easy - requires only one person. Basically, all you do is remove one nut on the hood near the hinge, stick on the upper bracket, and tighten the nut. Then you do the same for the bottom bracket. Do this on both sides while the old prop rod is holding the hood up. Then close hood to check fit - there should be no problems. Raise and prop hood again, screw top end of strut into upper bracket, pop lower end on lower bracket - repeat for other side, lower old prop, and you're done. Shouldn't take more than 10 - 15 min, and most of that will be reading the instructions carefully. There should be no adjusting required - the fit is perfect. I've done both of our Cruisers and everything worked right the first time. Blane makes a great product and is a great, customer-oriented vendor.
