Old 11 Apr 2013, 07:20 pm
ryan350 ryan350 is offline
Default ignition switch wont turn to start postion
I have a 2001 pt cruiser automatic transmission. the car will not start. the starter is new all the relays are good and i replaced the ignition key cylinder. i brought it to my mechanic and he said that i need to replace the steering column. i been looking for a used steering column but no luck finding one. and the dealership wants to charge $1200 for a new one. my mechanic said that the key wont go to the start postion. does anyone know what part inside the steering column would be causing the problem? Also i found a steering column for a 2002 pt cruiser the junk yard said that it was a little bit different. i was thinking i could take the part out of the 2002 steering column and replace it in my 2001 pt cruiser. unfortunaly i have no idea what mechanical part is broken. has anyone had this problem if so please help. thanks guys
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
