23 Oct 2003, 02:54 pm
quote:Originally posted by Kirby
Stage 2 Hardware:
4 - +30% fuel injectors
1 - 3.0 Bar TIP sensor
1 - 3.0 Bar MAP sensor
1 - High preload wastegate actuator
1 - Stage 2 PCM
1 - Turbo toys kit
1 - 2.5" cat-back exhaust system (required, but not included)
Stage 2 Turbo Toys:
It is a 3 switch bezel that fits in the space between the rear defrost and power outlet.
IC Sprayers - The switch is a three position switch: OFF, AUTO, and MANUAL. The AUTO mode is an algorithm that operates the sprayers based on certain vehicle and engine parameters. The manual mode will allow the driver to override the acontrol algorithm and spray on demand.
Dial-A-Boost - The dial is a four position dial. Each position controls the boost to a different level. The dial will allow the driver to reduce the engine output from the Stage 2 advertised output of 280 ft-lb and 260 hp. This will be great for rain, snow, and mud.
High Octane Fuel - This switch will change the engine calibration. It will require 100 R+M/2 octane unleaded fuel. Both torque and power will be increase above 280 ft-lb and 260 hp.
Kirby / Anyone - Is the above still valid for the Stage II?
\'03 GT Inferno Red AutoStick - Stage 1 - Air Box Mods & K&N Filter - AMX Intake Down Pipe - Flowmaster 40 Series Exhaust - Magnacor 8.5mm Ignition Wires - Pin Stripping - Chrome Side Spears - Chrome Tail Light Covers - Chrome Fuel Door - E&G Custom Grill - Painted Rear Mud Guards - 3-D Liquid Flames - Chrome/Red Neon Washer Nozzles - Interior Neon
