Old 21 Jul 2013, 10:51 pm
EvilSpirit EvilSpirit is offline
Default Re: Still running hot!
If you have checked the obvious - hi/low cooling fan speeds, coolant level, thermostat, gauge accuracy, etc, and it still runs hot - over 1/2 way on the gauge - try turning the heater to full heat and the blower on high to see if the temp drops. If it does, the radiator is probably partially plugged and either needs flushed or replaced. Both procedures have been discussed fully in other posts - look in the posts stickied in the tech section.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
