Old 30 Aug 2013, 03:32 pm
CREWZIN CREWZIN is offline
Default Re: P0601 error replacement parts
First, I'll save someone the trouble....Holy post revival, batman. Meaning you've replied to a post that 6 years old.
If you just found the fault code, who knows how long it's been there. Probably a glitch. Just take off the negative battery cable for 5 minutes, step on the brake pedal and put everything back together. That will clear the code from memory and reset the computer. Might run rough for a minute or two while the computer re-learns your settings. Don't worry about it unless it comes up again.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
