The DZ is probably as low as you can get. There is just not that much suspension to get rid of. Even with the car resting on trimmed bump stops it will still be pretty far of the ground. The factory struts only have 4 1/2 to 5 1/2 inches of compresion ( or drop )from ride hight. I have the 3 inch gold lines and have very little travel left, and am quite far off the ground. And with the front fenders as they are you cant even do a body drop to make up more drop. The only thing you can do is get the Air kit and add a body kis as mentioned above.
