Thread: Boost Question
Old 04 Apr 2004, 10:54 am
Mel K Mel K is offline
Default Boost Question
I have looked at boost controllers for more perforance, but I believe that you dial in a setting and that's your boost. Our stock controller, if I am correct has a variable boost depending upon data received by our chips. If so, does this data show what the boost is to the turbo and if it does could this boost sensor be reprogrammed or tricked into showing 2 lbs. under actual? If so, we would have the advantage of variable boost, yet higher boost throughout the range than stock. Possible or Impossible?
