Thread: opps> wrong gas
Old 12 Nov 2003, 11:16 am
RODRUN RODRUN is offline
I usually dont let the tank go below half way before I fill up again.
And in cooler weather I top off with the good stuff and next time top off with the cheap stuff and back and forth like that. Most people have the misconception that if a car runs good on reg. then premo will be better. But cars today and the putors work well together and if you owners man. says the car only needs the lower octane then that is what you should run, you can cause problems running the good stuff in a car that only needs reg.. One little carbon deposit and it it ping city.
Sorry.[8D]
You should be ok, just top out when you can with the good stuff. I dont need to tell you the differance between the regular cars and Turbo and Blown type engines.
03 Steel Blue Pearl Turbo, Stage 1, Mopar BOV, Magnaflow performance muffler, My Air Box mod., AMXpipe W/K&N filter, LED lighting,PT Tunning rear lowering springs & BGT Strut tower brace, Hankooks Ventus tires, Rage Motif 17 in. wheels. Tribal pinstrips by Palmer (who else), Color match paint by Etouchup.com, Plugs and wires by Sparkplugs.com, http://members.cardomain.com/rodrungtpt
