Do not even think about trying it yourself!
#1 a convertible is simply not a sedan with the top removed.
#2 The convert. requires a different under body design.
It requires additional support rails built in to the underbody.
Should you remove the metal top from a car you are also removing its intended and required dementional stability.
It would be fine if all you want to do is look at it.
Try driving it and you will very soon find yourself in deep trouble.
Even before you find your car "out of square"
As they say their is a lot more to it then meets the eye.
Take care
[8]
