Some people should continue to learn about new things and not settle for what they once knew as absolute!
PLEASE NOTE!
This module is PLUG-and-PLAY.
No Need To Visit the Dealer! Comes With 1 Year Warranty!
2002 02 Chrysler PT Cruiser ECU ECM PCM engine computer engine control module brain box
Many ecu, tcm, pcm, etc., from re-builders have the ability to load the appropriate information into the units so the need to go to a dealer and spend more money not necessary.
Originally Posted by quicksilverdon
A "flush" of your transmission with a filter change by a place with a flushing machine runs about $200 - be sure that all that is used is ATF + 4.
^^Don this is good info and generally I would also recommend it but in this case I sense the need for inexpensive and something that easily and affordable be accomplished now?
To be taken into consideration it is not necessary get a transmission flushed unless you have discolored fluid or during the filter change find unusual amounts of copper or aluminum in the pan.
A simple 45 minute DIY driveway transmission service will generally do the trick.
