Old 05 Mar 2014, 10:35 pm
tommifx tommifx is offline
Default Re: Trans Solenoid pack bad after TCM change?
Originally Posted by wwpptc View Post
Read the following instructions in section #6 below---twice. Did you or they follow these procedures correctly? If not you may have started the replacement procedure using a "good" TCM to replace the apparently "bad" one, but you probably didn't finish with one.
Jerry
Not quite what your point is, but I had the correctly programmed one, so I guess it should be fine. Apart from that I followed the instructions, I guess there is not much you can do wrong there....
I checked the tranny fluid and this seems pretty clean, no dirt and fully transparent....
So transmission fluid change and I'll also order the solenoids, seems also a thing you can do yourself.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
