Originally Posted by tommifx
Not quite what your point is, but I had the correctly programmed one, so I guess it should be fine. Apart from that I followed the instructions, I guess there is not much you can do wrong there....
I checked the tranny fluid and this seems pretty clean, no dirt and fully transparent....
So transmission fluid change and I'll also order the solenoids, seems also a thing you can do yourself.
I thought my point was very clear----It's very possable to inadvertently damage the TCM itself if the installer doesn't follow proper precautions when installing the unit. That was the section imediately following the #6 that had the large arrow pointing to it and starts with the word ---CAUTION---. I would have thought that would be hard to miss. Mental note to self--use larger arrows.
IF you followed the instructions then you should be fine.
Jerry
