Old 11 Mar 2014, 09:00 am
Handy_Cruiser's Avatar
Handy_Cruiser Handy_Cruiser is offline
Default Re: 01 PT Cruiser fires up but dies
First thing to try - disconnect the negative cable and then press and hold the break peddle down with the key on for about a minute. Then reconnect the cable and see if the car starts normally.
If that doesn't work, I'd be thinking about a bad fuel pump. What you described as the symptoms sound a lot like a bad fuel pump. Luckily, the 2001 PT has a Schrader valve on the end of the fuel rail where you can check fuel pressure. But that doesn't usually have anything to do with changing out a weak battery. So I'd look for something else first. Do you have any trouble codes?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
