Old 11 Mar 2014, 04:38 pm
Default Re: REAR WHEEL BEARING??
Originally Posted by njsteve1 View Post
I had a similar issue with my 03. I had a clucking/clicking sound every time I used the brakes. Drove me nuts. Check all the rear suspension could not find anything. What I finally found was the inner brake pad had came loose from the attach spring mounting clip. The inner brake pad was rattling around against the metal hardware.
I had that happen also, BUT:
1) He says it only clicks when hit hits the brakes, with the pad problem, the clicking would go away when I hit the brakes...
2) He mentions an auto adjuster, which implies rear drums...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
